Release Notes: Nuki Android App 2024.7.1
What's new?
Interactive Widgets
Lock your Nuki device and see its state at a glance: We are releasing new interactive widgets for your Android home screen. There are two main functionalities for the Widgets:
Display status
Within the widget you can always see the status of your Smart Lock, Opener or Smart Door:
  • Lock state: See if your device is locked or unlocked.
  • Battery state: Receive a warning if your battery is running low.
  • Door state: If your device is connected to a door sensor, the widget also shows you if your door is open or closed.
The Android Widget shows the status unlocked of the Smart Lock called Home.
Lock actions
You can now add up to two lock actions to your widget. When pressing the lock action button your device performs the action immediately without having to open the app anymore.
The Android Widget shows the status locked of the Smart Lock called Home. Additionally you can Unlock and Lock the Smart Lock.
How to receive the current state? Simply reload the widget via the button on the top right corner. Also, if you lock your device via the widget, it updates the status.
Note: You need Android 12 or above to use the new Nuki widgets.
  • You can now use our Matter integration with Amazon Alexa as well. Here you can read more about Matter capable Smart Home hubs.
  • We fixed a bug that prevented users from logging out of their Nuki Web account on Android. You can now log out of your Nuki Web account as usual.
  • Your preferences concerning Auto Unlock are now displayed correctly again.
  • We reworked our error messages in the activity log. You now have better insights on what happened and what to do next directly in the app.
