We are excited to announce our new retrofit Smart Locks today: The Smart Lock Pro and the Smart Lock Go!
Discover the new Smart Lock Pro & Go
Together with the new Smart Locks, here are the new App features you can expect:
Make a backup and transfer all relevant data to your new Smart Lock
Are you already using a Nuki Smart Lock and are interested in a Smart Lock Pro or Go? With the new backup feature, the transfer is very easy. Simply make a backup of your current Smart Lock and transfer all relevant data to your new Smart Lock Pro or Go.
Your Smart Lock Pro comes with new locking speeds
Do you want your Smart Lock to be as fast as possible so that you don’t have to wait in front of your door? Do you want it to be smooth so it does not disturb you while you are concentrating? Nuki created three new locking speed modes for your Smart Lock Pro: Insane, Standard and Gentle. You can select your preferred mode within your Nuki App.
Do you want your Smart Lock to be fast during the day and smooth while you sleep? Simply use “Insane” as your preferred locking speed. Next, activate Night Mode and enable “Gentle” locking during night mode.
DIY installation
To make installation as easy as possible, we created app flows to guide you through the mounting of the new Smart Locks.
Enhanced security code
The 4-digit has changed to a mandatory 6-digit security code to make your Smart Lock even more secure. From now on, this code will also be used during bluetooth pairing. But don’t worry: The Nuki App can remember this code for you as usual.
Â
- We adapted the MQTT activation: Configuring your MQTT integration via the Nuki App is now even more user friendly.
- You can now see your Nuki device status more quickly and lock your device with your iPhone even faster.
- We have also been working on minor changes and improvements in the background. This makes the Nuki App run even more smoothly.
