Your Keypad works with two button cells (CR2032), which are included in delivery. The average life of the batteries is 12-18 months; this corresponds to about 30,000 lock actions.
Steps to replace batteries
- Open the housing by detaching the lower part of the Keypad from the upper one - this can be done easily without tools.
If the batteries are not easy to remove, use a flat-head screwdriver to remove the batteries.
- Now insert two new CR2032 batteries (button cells) and close the case carefully.
