Release Notes: Nuki Smart Lock 4.2.8
What's new?
We are excited to announce the latest firmware update for the Smart Lock and Smart Lock Pro (4th Generation). Here are the improvements and new features you can expect:
  • The Matter Standard 1.2 distinguishes between unlocking and opening the door. With this firmware update, you can unlock your door without pulling the latch. For now, this new feature is only available in case you use Home Assistant as a Matter Hub.
  • Stability improvements for the Wi-Fi connection of the Smart Lock Pro.
  • Fix for a bug which caused delays on the push notifications and activity log synchronizations. This affected Smart Locks that are connected to Nuki Web via a Nuki Bridge.
  • Minor changes and improvements in the background ensure that the Smart Lock runs even more smoothly.
