Matter integration
This article concerns:
From the Smart Lock (4th Generation) onwards the Smart Lock supports Matter, the new standard for Smart Home devices. Matter allows secure control of your Smart Home devices across various platforms. It enables seamless integration of your Smart Lock into leading Smart Home ecosystems. Local Matter integration operates within your own network, offering quick and secure control of your Smart Lock.
Supported Smart Home platforms are:
  • Apple Home
  • Samsung SmartThings
  • Google Home
  • Amazon Alexa
Note on Google Voice Commands:
Unfortunately, Google Home does not currently support unlocking and locking your door via voice commands. This is due to the switch to Gemini and a limitation regarding the security device action requiring a PIN.
Benefits of your Matter integration
Interoperability
Matter-enabled devices integrate effortlessly into your Smart Home. Each family member can use their preferred platform to control the Smart Home, enhancing user convenience and satisfaction.
Local integration
Matter-enabled devices communicate locally with hubs, ensuring your data never leaves your home. This local integration provides a secure and reliable way to control your Smart Home devices.
Easy activation
Activating Matter is simple and quick, taking just a few moments to set up. This makes it accessible for all users.
Modern connectivity
Nuki uses Matter via Thread. This network technology enhances the speed and stability of your Smart Home, providing a superior user experience.
Integration via Nuki Web
Beside the Matter integration Nuki also supports Google Home and Amazon Alexa integration via Nuki Web. This cloud service allows you to access and control your Smart Lock anytime, even when you're outside your home network. You can simultaneously use local Matter integration and cloud integration, offering the flexibility to enjoy the benefits of both approaches. This combined use provides fast local control and reliable remote access, with the cloud connection acting as a fallback for Matter integration.
