Restore a previously released firmware
Your Smart Lock is registered for the beta program, but you want to use the official firmware? Unsubscribe from the beta program to use the official firmware version again in the future.
Please be aware that downgrading to a previous version of the firmware is not possible once your Smart Lock has been updated with the beta firmware. If you choose to leave the beta program, you will need to wait for the next official release before updating your Smart Lock. However, after deactivating your device for beta versions, you will only receive regular firmware updates.
While beta releases are typically quite stable and are used by our team on a daily basis, they do not undergo the same extensive testing as official builds.
Note:
Beta versions are not yet officially released and may also contain bugs or inaccuracies. In rare cases it may be necessary to reset the Smart Lock to factory settings. Our support team will be happy to answer your questions and help you through the process.
