With the Fob you can conveniently lock or unlock your door via Bluetooth. For using the Fob as your smart key, simply pair your Fob with your Nuki device (e.g. Smart Lock)*. You can connect the Fob to up to 100 devices.
Pairing via Nuki App
You can set up and manage your Fob with the Nuki App. To connect the Fob and your device follow these steps:
- Open the Nuki App on your smartphone and navigate to the menu (top left, three bars).
- Select ”Manage devices” > ”Accessories” > ”Fob”.
- Follow the instructions in the Nuki App.
After the pairing, you'll find the Fob under ”Lock permissions” of the paired Nuki device. Further information can be found here: Manage Fob users
Pairing directly via Bluetooth
You can connect your Fob with your Nuki device by pressing the button of both devices. To pair the devices follow these steps:
- Get in Bluetooth range to your Nuki device.
- Hold down the button on the Nuki access solution (e.g. your Smart Lock) for 5 seconds to start the pairing mode. Pairing mode is idicated by the LED ring permanently glowing.
- Hold down the button on the Fob for 5 seconds to start the pairing mode. The Fob is in pairing mode when the light is permanently glowing.
- Now the devices are connecting. The pairing of the devices is finished when the lights stop glowing.
You can operate the Opener with the Fob. Note that the Fob's Bluetooth is approximately 10 meters. This range may be reduced by walls and other interference. For example, if your Opener is installed on an upper floor of an apartment building, the Fob might not be able to reach it.
