Fob battery
The Fob works with one battery (type CR1632). The battery is included.
How to replace the battery
To replace the battery, follow these steps:
  1. The battery compartment is located on the bottom of the Nuki Fob. To open the battery compartment, hold it firmly on both sides and pull it out powerfully.
  2. Replace the battery and insert the battery compartment back into the Fob.
You can change the battery by pulling out the battery compartment on the bottom of the fob.
