I want to control my Nuki device remotely. Which options do I have?
Depending on your setup, there are different ways to bring your device online.
  • The Smart Locks Ultra, Pro, Go, Pro of 4th Generation and 3.0 Pro as well as the Smart Module come with a built-in Wi-Fi module, so you don’t need any additional accessories to manage your device remotely. The setup is straightforward, requiring a Wi-Fi network with a standard 2.4 GHz signal. The built-in Wi-Fi supports integrations via Nuki Web and MQTT.
  • If you're using the Smart Lock Ultra, Pro, Go, a Smart Lock 4th Generation or a Smart Module you can use Remote Access via Thread. To use this option, you’ll need a Smart Home hub that supports Matter via Thread. Thread provides high stability and low battery consumption. This option supports integrations via Nuki Web, MQTT, and Matter.
  • If you're using a Smart Lock 4th Generation or a previous version, an Opener or a Smart Door: You can also use the Nuki Bridge. The setup is straightforward, requiring a Wi-Fi network with a standard 2.4 GHz signal. Once connected, you can integrate your devices through Nuki Web or use the Bridge API.
Note on Wi-Fi 6, WPA3 and 5 GHz network:
Neither the Smart Lock nor the Smart Module or the Bridge currently support Wi-Fi 6, the WPA3 security standard, or the 5 GHz network signal. Therefore, please use a Wi-Fi network with a 2.4 GHz signal and WPA2/3 mixed mode for smooth operation.
