Interactive Widgets
This article concerns:
  • Nuki iOS App
  • Nuki Android App
Lock your Nuki device and check its status at a glance with the Widgets for your home screen. iOS users can use the same widgets with CarPlay.
There are two main functionalities for the Widgets:
Display status in the widget
Within the widget you can always see the status of your Smart Lock:
  • Lock state: See if your device is locked or unlocked.
  • Battery state: Receive a warning if your battery is running low.
  • Door state: If your device is connected to a Door Sensor, the widget also shows you whether your door is open or closed.
Nuki iOS Widget Display status
Lock actions with the widget
You can now add up to two lock actions to your widget. When pressing the lock action button your device performs the action immediately without having to open the app anymore. This makes the locking even faster.
Nuki iOS Widget Lock actions
How to receive the current state? Simply reload the widget by tapping the button on the top right corner. Also, if you lock your device via the widget, it updates the status.
Note: You need iOS 17 or above / Android 12 or above to use the new Nuki widgets.
How to add a Widget
You can freely place Nuki widgets on your home screens. To add the home screen widget:
iOS:
  1. Enter jiggle mode: Tap and hold an empty space on the home screen until icons jiggle.
  2. Add widget: Tap ”Edit”, select the Nuki widget and size, then tap ”Add widget”.
  3. Customize: Tap and hold the widget, select ”Edit widget”.
Android:
  1. Tap and hold an empty space on the home screen until further options appear.
  2. Tap on „Widgets“ and add the Nuki widget.
  3. Customize: Tap and hold the widget until further options appear.
CarPlay (iOS):
  1. Open the settings on your iPhone.
  2. Go to “General” > “CarPlay” and select the Nuki widget from the CarPlay widget list.
Note on CarPlay widgets:
You do not need to open the Nuki app or unlock your phone to use the Nuki CarPlay widget. If you still have to do either of these things, delete the widget and add it again. When adding the widget, make sure to select it from the CarPlay widget list and not the "Other" list.
iOS: Nuki controls for your Control Center
You can now add Nuki controls for iOS 18. You can easily lock and unlock your door from the Control Center.
