- Keypad 2
- Keypad 2 NFC
The Keypad is the ideal accessory for your Nuki Smart Lock. Users of all ages can open the door with their fingerprint. This also applies to our youngest users. Because the features found in children's fingerprints are usually already sufficient for successful recognition. The Keypad is also self-learning. Each time the sensor successfully recognizes a finger, it refines the stored information. It learns and grows with its users.
As with any fingerprint sensor, the reliability of recognition is affected by several factors. If the fingers are very small and the features of the fingerprint are only weak, recognition is more prone to error. Moisture and dirt also have a negative impact on recognition.
For security reasons, a fingerprint is always linked to an entry code. You can open your door by entering the 6-digit entry code or by placing your finger on the sensor.
