You are visiting Nuki support for the United States of America 🇺🇸. Do you want to stay or go to Nuki Support for the rest of the world?
Keyless, flexible access to your home. Made possible by the smart access solutions from Nuki.
Our most advanced retrofit Smart Lock is ready for your deadbolt.
Open your door within seconds with fingerprint or PIN code.
Always know that your door is securely closed and locked.
Access via code, even without a smartphone. Perfect for your vacation rental.
Europe’s #1 Smart Lock - now unlocking homes across the U.S.
Nuki makes everyday life simpler, faster, and totally key-free.
Stress-free hosting with Nuki Premium.
Digital key sharing for offices and shared spaces.
Technological innovation and product design made in Austria. Built for American homes.
You have more than one Nuki device and want to use Auto Unlock? Then, the feature "Consider nearby devices" might be helpful for you. It makes sure that Auto Unlock only unlocks the door you use to enter your home. At the same time Auto Unlock is canceled for other devices nearby. This means, all other doors remain securely locked.
Your house has a front and a back door.At each door a Smart Lock is installed. Auto Unlock and “Consider nearby devices” is enabled for both devices.Today, you enter your home via the back door.Of course, Nuki should only unlock the door you use to enter your home. In this case the front door stays securely locked.
