Use the Smart Lock U.S. with a Wear OS smartwatch
This article concerns:
  • Nuki Android App
With your Wear OS smartwatch you can leave your smartphone at home. Because in Bluetooth range you can control your Nuki device directly via your watch.
You have a Wear OS smartwatch with LTE? Then you can access your Nuki devices remotely at any time, while your smartphone stays at home.
Installation & Setup
  1. Make sure your watch and smartphone are connected.
  2. Press the power button to access the app list. Scroll down to the Google Play Store icon and search for the Nuki App.
  3. All connected Nuki devices will now be displayed on your watch.
From now on you can control your Nuki device via your smartwatch.
Compatibility & connection
  • Nuki App update
    We recommend to update the Nuki App on a regular basis. By using the latest app version you benefit from the latest app improvements.
  • Compatibility
    Nuki is compatible with Wear OS 2.0 or newer.
  • Direct Bluetooth communication
    Within Bluetooth range, you can control your Nuki device directly via your watch. You don’t need to have your smartphone with you.
  • Online access
    You use a Wear OS smartwatch with internet access? All your Nuki devices can be controlled remotely directly from your watch.
Tip!
In case of connection problems or errors in the status display, always reboot your smartphone and your watch.
Support of the Wear OS Tiles
In the list of available tiles on your watch you will now also find a Nuki Tile. Select the Nuki Tile and add it to the carousel on your watch.
The Nuki Tile shows buttons for up to three devices and a ”More” button.
  • Clicking on one of the buttons opens the Wear OS app and takes you directly to the selected device.
  • Clicking the ”More” button opens the Wear OS app without going to a specific device.
This way the Nuki Tile provides you easy and fast access to your Nuki devices.
