Huawei smartwatch
This article concerns:
  • Nuki Android App
One of the most significant advantages of smartwatches is that you don't need your smartphone so often. From now on, you can even leave it at home. Because in Bluetooth range you can control your Nuki device directly via your watch.
Installation & Setup
  1. Make sure your Watch and smartphone are connected.
    Please note that the ”Huawei Health” app must be installed. If the ”Huawei Health” app is not yet installed, you can download it from the Huawei AppGallery on your smartphone.
  2. Open the Huawei AppGallery and install the Nuki App on your watch.
  3. Open the Nuki App on your smartphone and select ”Connect Huawei Watch” in the menu. The connection to your watch will be established.
    The menu item ”Connect Huawei Watch” is only displayed if the ”Huawei Health” app has been installed before.
  4. Select the desired Nuki device.
From now on you can control your Nuki device via your smartwatch.
Compatibility & connection
  • Direct Bluetooth communication
    Within Bluetooth range, you can control your Nuki device directly via your watch. You don’t need to have your smartphone with you.
  • Compatibility
    Lite Wearables (GT Series) cannot be used with Nuki.
    Also, currently not supported is the Huawei Watch Ultimate.
  • Language availability
    You can use your app on your smartwatch in English, German, French, Italian, Spanish and Dutch.
Tip!
In case of connection problems or errors in the status display, always reboot your smartphone and your watch.
