LED Signalization of the Smart Lock U.S.
You can see the status of your door in the Nuki App and on the Smart Lock. On the Smart Lock, there is a LED signal on the rotating ring.
In addition to the illuminated ring, the the Smart Lock has a red LED in the upper segment of the ring. This LED is mostly used to display errors and warnings directly on the Smart Lock. If the red LED lights up, open the Nuki App to get further information about the error or warning and troubleshooting steps.
Details on the Smart Lock's LED signalization
State LED signalization
Smart Lock locked, inactive The LED ring is off. Led is off
Smart Lock unlocked The top segment of the LED ring flashes 1x every 1.5 seconds. Led is flashing
Pairing mode
The Smart Lock can be connected with other Bluetooth devices.
The LED ring is permanently glowing. Led lights up
Maintenance mode
The firmware of the Smart Lock can be updated or it can be reset to factory settings.
The top segment of the LED ring is permanently glowing. Led top segment lights up
Smart Lock is charging
The Smart Lock is now charging on or off the door.
The red segment of the LED ring first flashes and then glows dimmed. As soon as it is fully charged, the red segment turns off again. Led flashes red
Door Sensor
Door open
Door Sensor
Door closed
The lower segment of the LED ring is permanently glowing. Led bottom segment lights up
Error LED signalization
- Battery state crititcal
Please load the batteries.
- Battery state of the Nuki accessory (Keypad or Door Sensor) critical
Please replace the batteries.
- No Wi-Fi connection
- Nuki Door Sensor removed
The red segment of the LED ring flashes 1x every 15 seconds (in total 4x).
Note: The error signalization is displayed directly after the locking action.
Led flashes red
Uncalibrated
The Smart Lock is not calibrated. The status was lost due to external influences. Please calibrate it with the Nuki App.
The red segment of the LED ring flashes 4x every 15 seconds. Led flashes red
Switch off the LED
You can always turn off your device's flashing and glowing. Simply tap on your device in your Nuki App, enter the settings, and go to “Features & Configuration”, “Button, LED  & Sound”, or “Button & LED”. Here, you can disable the LED signal. Switching off the LED signalization saves energy and prolongs battery life.
