Activate MQTT via the Nuki App
This article concerns:
  • Smart Lock Ultra
  • Smart Lock Pro (5th Gen.)
  • Smart Lock Go
  • Smart Locks (4th Generation)
  • Smart Lock 3.0 Pro
  • Which Smart Lock do I have?
  • Smart Module
The Nuki device supports MQTT integration via Wi-Fi or Thread networks. You can configure MQTT in your Nuki App including features like auto discovery for Home Assistant and locking permissions via the interface.
Configure MQTT via the Nuki App
  1. Open the Nuki App, tap the desired Nuki device and open the settings.
  2. Select ”Features & Configuration” > ”Smart Home” > ”MQTT”.
  3. Follow the app instructions to proceed with the activation.
Additionally to the host name, username and password, you can configure the following options in the Nuki App:
  • Auto discovery
    With auto discovery enabled, your Nuki device will automatically be recognized by Home Assistant after being added to the network.
  • Allow locking
    You can enable or disable locking actions via MQTT. The communication via the interface can be limited to exchanging information only.
Security
Although authentication with username and password takes place, communication between Nuki device and broker is not encrypted. The MQTT connections are always established on port 1883. There is no additional encryption beyond the Wi-Fi encryption when using MQTT via Wi-Fi. This means that the security follows the security level of your network. However, you can limit the communication via the interface to exchanging information only. In the Nuki App you can define if locking actions can be executed via MQTT or not (”Configure MQTT” > ”Allow locking”).
