- Smart Lock Ultra
- Smart Lock Pro (5th Gen.)
- Smart Lock Go
- Smart Locks (4th Generation)
- Smart Lock 3.0 Pro
- Which Smart Lock do I have?
- Smart Module
In this troubleshooting article, you'll find solutions for errors that may occur during the activation and configuration of your Nuki device with the MQTT protocol. You'll learn how to update your firmware, connect your Nuki device to the network via Wi-Fi or Thread, and ensure you're using the correct MQTT protocol version. Make sure to check that the client identifier is unique to each connected device and that your username and password are correctly authorized by the MQTT broker.
Troubleshooting steps
Update the firmware of your Nuki device
Learn more about how to update the firmware of your Nuki device. -
Connect your Nuki device to your network
First activate the built-in Wi-Fi module or Matter via Thread and connect your Nuki device to your network. -
Make sure that the protocol versions match
During configuration you can determine which MQTT protocol version should be used when making a connection to the server. If the MQTT connection cannot be established, check the configuration. Version 3.1.1 and newer are supported. -
Check the “identifier”
The client identifier is a string that clearly identifies a MQTT client. Every identifier must be assigned to an individual connected client.
If the app indicates that the MQTT connection cannot be established due to an incorrect identifier, please contact our Support Team. -
Check username and password
The MQTT connection cannot be established if username and password are not authorized for the MQTT broker. Please check your configuration.
Although authentication with username and password takes place, communication between Nuki device and broker is not encrypted. The MQTT connections are always established on port 1883. There is no additional encryption beyond the Wi-Fi encryption when using MQTT via Wi-Fi. This means that the security follows the security level of your network. However, you can limit the communication via the interface to exchanging information only. In the Nuki App you can define if locking actions can be executed via MQTT or not (”Configure MQTT” > ”Allow locking”).
