Mounting and installation of the Opener
The Nuki App guides you through the installation of your Opener.
Like all Nuki products, the Opener is designed for DIY installation. It is connected using the screw terminals of your intercom. The Nuki App shows you which wires of the Opener and the intercom have to be connected. To display the appropriate connection diagram for your system, the Nuki App asks for the manufacturer and model of your intercom during the initial setup. Please only use the wiring diagrams specified by us.
Mounting instructions
You can glue or screw the Opener to the wall. If you want to use the adhesive pad, make sure that the surface is even and free from grease, dust, and dirt. Alternatively, you can also screw the Opener to the wall. You can either use the included screws and dowels, or other installation materials that are appropriate for the wall texture.
Note:
Only use the Nuki Opener with intercom systems with a maximum voltage of 50 V AC/DC and a maximum current of 2 A.
