This article concerns:
- Nuki iOS App
With a smartwatch, you won't need to use your smartphone as often, and you can even leave it at home. Because in Bluetooth range you can control your Nuki device directly via your watch.
With an Apple Watch LTE you can even control your Nuki devices remotely without having your iPhone with you.
Installation & Setup
- Make sure your Apple Watch and iPhone are connected.
- Open the ”Watch” app on your iPhone. Now click on ”Nuki” and activate the option ”show on Apple Watch”.
- All connected Nuki devices will now be displayed on your watch.
- If you are using multiple Nuki devices, they will be listed according to their order in the Nuki App on your iPhone. You can switch between the different devices by swiping left or right. If you want to move a specific device to the first position, set it as your favorite in the Nuki App on your iPhone.
From now on you can control your Nuki device via your Apple Watch.
Compatibility & connection
- Nearby communication
Within Bluetooth range, you can control your Nuki device directly via your watch. You don’t need to have your smartphone with you. - Remote communication
You can control your Nuki devices from afar as well.
Do you have an Apple Watch without LTE?
You need your iPhone with you. However, the iPhone can stay in your pocket as long as your Apple Watch and iPhone are connected via Bluetooth .
Do you have an Apple Watch LTE?
You don't need your iPhone even if you want to operate your door remotely. Your Apple Watch LTE communicates directly with your Nuki device. - Compatibility
Nuki is compatible with WatchOS 8 and later.
Tip!
In case of connection problems or errors in the status display, always reboot your iPhone and your Apple Watch.
