Release Notes: Nuki Android App 2026.11.1
Discover the Nuki Smart Module
We are proud to present the newest Nuki product: The Smart Module! This is Nuki’s access solution for motorized locks. You can plan it with your new door or install it as a flush-mounted retrofit solution. The Smart Module comes with all Nuki benefits:
  • Connection via Bluetooth and Wi-Fi, and can be easily integrated into your smart home using Matter via Thread.
  • Various options to open your door e.g. via app, accessories or fully automated via Auto Unlock.
  • Remote access via the built-in Wi-Fi or via Thread.
  • Easy sharing of invitations to your Nuki device.
  • Seamless design: The Smart Module is integrated directly into your door or a flush-mounted box.
Smart-Module installed in door
Moreover, the Smart Module comes with a new feature, the passage mode. If your motorized lock supports this option, you can keep your door unlocked for a chosen period of time.
We recommend finding a professional partner from our network for installation.
… about the Nuki Smart Module.
Are you using a Keypad 2 NFC? It now supports a new security feature: Theft detection. With a theft detection battery compartment, the Keypad can notify you as soon as it is moved. Make sure to install the latest app version and firmware version for your Smart Lock and Keypad.
We have also been working on minor changes and improvements in the background. This makes the Nuki App run even more smoothly.
