We are excited to announce the latest firmware update for the Smart Lock and Smart Lock Pro (4th Generation).
Overview of this release
- Discover the white version of the Keypad 2 NFC.
- Know when your Keypad 2 NFC is moved with Theft detection.
- Performance improvements and bug fixes.
What's new
Here are the improvements you can expect:
We present the white version of the Nuki Keypad 2 NFC. The Keypad 2 NFC comes with Tap to Unlock: Simply tap your smartphone or smartwatch on the Keypad to unlock your door. If you have an Apple or Samsung setup with a Matter-capable Hub, this also works with Samsung Digital Keys or Apple Home Keys.
Are you using a Keypad 2 NFC? It now supports a new security feature: Theft detection. With a theft detection battery compartment, the Keypad can notify you as soon as it is moved. Make sure to install the latest app version and firmware version for your Smart Lock and Keypad.
Minor changes and improvements in the background ensure that the Smart Lock runs even more smoothly.
12/11/2026
Did you know that you can update the firmware of your accessory? Learn more about:
