This article concerns:
- Door Sensor
- Smart Lock
With the Nuki App you can reset your Door Sensor to factory settings. To do so, follow these steps:
- Open the menu (top left) of the Nuki App and tap on ”Help”.
- Tap on ”Factory reset”.
- Select ”Nuki Door Sensor factory reset”.
- Now follow the instructions in the Nuki App.
Note:
By resetting to factory settings, all data will be irrevocably deleted. After the reset, you can set up your Door Sensor again.
