Connection state
The Nuki app provides an overview of the connection status of your Nuki device. To access this information, simply tap on your device and enter its settings. Then, go to “Connection Info”.
How the connection info is structured
On the connection info screen, you can find details about your:
  1. Bluetooth Access: Quality of your Bluetooth connection
  2. Remote Access: Quality of your remote connection
The connection quality is color-coded:
  • Green: stable connection
  • Yellow: unstable connection
  • Grey: no connection (i. e. because you are out of Bluetooth range or Wi-Fi is not set up yet)
  • Red: unable to connect (Error)
Note:
A change in the connection quality might take a 1–2 minutes until it is visible on this screen.
Bluetooth Access
The Nuki App shows you information about the quality of your Bluetooth connection. If necessary the app displays tips on how to improve it.
Under optimal conditions you can control your Nuki device via Bluetooth from a distance of about 33 ft. Doors, walls and other interference can reduce this range.
Bluetooth troubleshooting:
If you can't connect your device via Bluetooth, please follow these Bluetooth connection troubleshooting steps.
Remote Access
The Nuki App shows you how your device is online (via Matter or built-in Wi-Fi). It also gives you information about the quality of the connection and—if necessary—tips on how to improve it.
Matter over Thread
You can access your Smart Lock remotely using Thread. This new Smart Home standard is more stable and requires less energy than Wi-Fi. Here, you can learn more about:
Matter over Thread troubleshooting:
Does your Matter integration not work as intended? Please try the Matter over Thread troubleshooting steps.
Built-in Wi-Fi module
The Smart Lock has a built-in Wi-Fi module. Here is how to activate the built-in Wi-Fi module.
Wi-Fi module troubleshooting:
If there is no connection via the Wi-Fi module, please follow these troubleshooting steps for the Wi-Fi module.
