Locking directly with your Nuki device
You have several options to lock and unlock directly with your Smart Lock: You can control your Smart Lock by pressing the button or turning the knob. When leaving your home simply press the button twice to activate Lock`n`Go. You can always open your door with your mechanical key from the outside.
Locking your device via button or key
From the inside, you can lock or unlock your door by pressing the button on your Smart Lock. Alternatively, you can simply turn the knob on the Smart Lock. From the outside, you can always lock and unlock your door with your mechanical key.
Childproof lock:
Do your children love to press the button on the Smart Lock and lock and unlock it countless times? We have a tip for you: Deactivate the button on the Smart Lock. To do this, open your Nuki App. Tap on the desired Smart Lock and open the settings. Go to “ Features & Configuration” “Button & LED”. Now deactivate “Allow locking operations”. This means that even the youngest children can no longer use the button to lock the door.
Lock ’n’ Go - press the button and leave your home
The Lock ’n’ Go feature is especially useful if you want to leave your home. When you press the button on your Smart Lock twice, the door will be unlocked (if it is not already unlocked). Then, you have 20 seconds to go out the door. After 20 seconds, the door locks behind you. Your smartphone remains in your pocket.
You can change the time span until your door is locked: Tap on your Smart Lock and enter the settings. Then go to “Features & Configuration” “Lock ‘n’ Go”. You can set a time span from 5 to 60 seconds according to your preferences.
You paired a Door Sensor to your Smart Lock? Now, it locks your door as soon as it is closed and the latest after the time period you set in your app.
If you have started Lock ’n’ Go and want to cancel it, just press the button twice again.
You can also activate Lock ‘n’ Go via your smartphone.
Smart Lock locks automatically with Lock n Go
Learn more about:
Locking with the Nuki App
