Wi-Fi connection
This article concerns:
An unstable Wi-Fi connection leads to higher power consumption.
The stability of the Wi-Fi connection influences not only the remote access. It also impacts battery life. If the Wi-Fi connection is frequently interrupted, the Smart Lock exits the battery-saving sleep mode to reconnect to the network. This requires additional power and reduces battery life.
Therefore, make sure that your Smart Lock has a good Wi-Fi connection to your router. Reduce the distance between the router and your Smart Lock to optimize the Wi-Fi signal strength.
Note on Remote Access:
To access your Smart Lock remotely you need Nuki Premium.
