What is “Consider nearby devices” within Auto Unlock?
This article concerns:
  • Smart Lock
  • Smart Door
You have more than one Nuki device and want to use Auto Unlock? Then, the feature "Consider nearby devices" might be helpful for you. It makes sure that Auto Unlock only unlocks the door you use to enter your home. At the same time Auto Unlock is canceled for other devices nearby. This means, all other doors remain securely locked.
This is how “Consider nearby devices” works:
An Example:
Your house has a front and a back door.
At each door a Smart Lock is installed. Auto Unlock and “Consider nearby devices” is enabled for both devices.
Today, you enter your home via the back door.
Of course, Nuki should only unlock the door you use to enter your home. In this case the front door stays securely locked.
