- Smart Lock
- Opener
- Smart Module
- Smart Door
When entering the Geofence the Nuki App starts searching for your Nuki device via Bluetooth. If your device is found within the specified time and a Bluetooth connection has been established, Nuki starts Auto Unlock. If not, Auto Unlock is canceled.
How long should the Nuki App search for your device via Bluetooth?
The optimum duration of the Bluetooth search depends on your individual needs. By default, the Nuki App searches for your Nuki device for 20 minutes.
You can also set the duration manually via the expert settings. Simply choose a period between 5 and 40 minutes.
- You have chosen a very small geofence or you usually drive home by car. There are only a few moments between entering the geofence and arriving home. A short search time for your device is sufficient for a perfect Auto Unlock experience.
- After entering the geofence you often do one or two things (shopping etc.) before you go home. A longer Bluetooth search can be handy to let Nuki open the door for you at the right time – even if you don’t go home directly.
In the expert settings, we offer our users a wide range of options. From these, you can choose the ideal settings for your individual use case.
Before making any changes, the Auto Unlock feature should work properly with the default settings. Changes to the expert settings are made at your own risk. If you modify the expert settings, we can only provide limited support.
How to change expert settings?
Simply tap on your device and enter the settings. Go to “Auto Unlock” > “Expert settings”. Here, you can make changes according to your preferences.
