Shortcuts provide quick access and seamless integration with Siri, Spotlight, and Apple Watches. Here, you'll discover the benefits of the reworked shortcuts and how to make the most of them.
Benefits of reworked Shortcuts
Instant availability
After installing the Nuki App, shortcuts are immediately available in Spotlight, Siri, and the Shortcuts app, providing quick and easy access. -
Dynamic updates
Shortcuts automatically update when devices are added or removed, or when device names are changed, ensuring you always have the latest information. -
Default activation
Shortcuts are enabled by default. There is no need for manual configuration, allowing you to use shortcuts immediately. -
Integration with Apple Watches
Access shortcuts directly from your Apple Watch, adding extra convenience to your user experience.
Here, you can find information on how to create iOS Shortcuts.
Supported Lock Actions
Through the shortcuts, you can perform one of the following actions:
- Unlock
- Lock
- Open the door
- Lock 'n' Go for Smart Lock and Smart Door
- Ring to Open for the Nuki Opener
Once the action is executed, you will receive a confirmation. Additionally, you can check the device status at any time via shortcuts.
Supported Siri phrases
With Siri Shortcuts, you can interact with the Nuki app easily and intuitively. Simply mention ”Nuki”, the name of your device, and the action you want to perform. Siri will respond and fulfill your requests.
How to Talk to Siri
When speaking to Siri, the phrase should include ”Nuki”, the ”Name of the device”, and the ”Action” you want to perform.
You want your Smart Lock named 'Home' to lock your door.
Say: ”Hey Siri! Lock Nuki 'Home'”
Siri confirms the action once it's successfully performed ('Home' locked).
