Charge your Smart Lock with built-in batteries
This article concerns:
With your Smart Lock Ultra or Pro you have two possibilities when it comes to charging: Mounted on the door or unmounted from the door.  The average charging time from empty to full is about 2 hours.
How to charge
Use the magnetic charging cable (2 m, USB-C to magnetic plug) for charging. It is included in the delivery. Use a power supply with a minimum of 10 watts.
Charging on the door
Your Smart Lock performs lock actions in this charging mode. Don't worry: The part of the Smart Lock where you plug in the magnetic charging cable doesn't rotate during locking. Nuki recommends this charging mode as you can still lock your door while you are charging.
Do you want to activate the “Charging on the door” mode? Simply plug in your charging cable. Be careful not to block the door with the cable. This charging mode is activated automatically.
Charging off the door
If you want to charge your Smart Lock unmounted from the door, we recommend the “Charging off the door” mode. It rejects automatic locking actions in this mode. These actions include:
  • Scheduling
  • Night Mode
  • Auto Unlock
  • Auto Lock
So if a family member approaches your home or the night mode triggers a locking action, your device will not move. After all, you are charging it unmounted from the door. It is best to use this mode during the night, as this is when the fewest people use your door. This is, how you unmount your Smart Lock.
Do you want to activate the “Charging off the door” mode? Plug in your charging cable and press the button in the next 15 seconds (while the Smart Lock is flashing red).
Have you activated the “Charging off the door” mode by mistake? Simply unplug the charging cable and plug it back on without pressing the button afterwards. You can still perform locking actions in the “Charging off the door” mode via the app or the button. Only automatic locking actions are rejected. So if the Smart Lock is mounted on the door, you can still operate it.
Check Charging Mode
You can always check which charging mode is active via the Nuki App and—if activated—in Nuki Web.
  • Nuki App: Enter the device settings and go to "Features & Configuration" > "Battery".
  • Nuki Web: Choose the device and enter “Manage Device” > "Battery level".
The Smart Lock also shows you that it is charging: The red segment of the LED ring blinks red for 15 seconds to indicate that you could activate the “Charging off the door” mode. After that, it glows, dimmed. As soon as it is fully charged, the red segment turns off again.
Battery type and battery life
Your Smart Locks Ultra and Pro have a built-in battery pack. Our many years of experience with Smart Locks have led us to choose these batteries for the best user experience. The batteries are permanently installed, so you don't have to service or replace them.
To ensure the long-term health of the battery your Smart Lock Pro (5th Gen.) and Ultra offers a charge limit. By default, your device will charge up to 80 %. In some cases, this number may be slightly above or below 80, depending on the temperature, your power supply and tolerances in production. You can deactivate this setting by entering the device settings then go to "Features & Configuration" > "Battery".
Average battery lifetime of the Smart Lock Ultra or Pro
Battery life depends heavily on your usage, door type, locking modes, and other factors. In general, you can expect the following ranges for your Smart Lock’s battery life before you need to recharge it:
  • 7—9 months without remote access*
  • 5—7 months with remote access via Thread*
  • 4—6 months with remote access via Wi-Fi*
*If charged to 100 %.
As soon as your battery status drops below 20 %, we inform you in several ways if the batteries of your Smart Lock are running low.
