Which Smart Lock do I have? This article helps you distinguish all Nuki Smart Lock generations. In general, there are two types: Smart Locks with built-in batteries and Smart Locks with removable batteries.
Check Smart Lock generation via app
Simply tap your device and select “Settings“. Then, go to ”Features & Configuration“ > ”General”. You can see your generation information there.
1) Smart Locks with built-in batteries
This is the newest Nuki Smart Lock generation. These Smart Locks come with all the features of previous Smart Locks, like Matter support or a built-in Wi-Fi, so that you do not need a Nuki Bridge to bring it online. The most recent feature of this generation is the option to restore a backup from a previous Smart Lock.
| Type | Color | Built-in Wi-Fi | Matter over Thread | Other |
| Smart Lock Pro (5th Generation) | Silver with black or white base ring | Retrofit 70 mm length |
| Smart Lock Ultra | Silver with black or white base ring | Comes with the Universal Cylinder 58 mm length |
2) Smart Locks with removable batteries or the Nuki Power Pack
This is the Smart Lock generation with the classic Nuki design. You can power these Smart Locks with 4 AA batteries or the Nuki Power Pack.
| Smart Lock Go | All white | Remote Access available through a one-time purchase | ||
| Smart Lock Pro (4th Generation) | Silver with black or white body | |||
| Smart Lock (4th Generation) | All white | Remote Access via Thread available through a one-time purchase | ||
| Smart Lock 3.0 Pro | Silver with black or white body | |||
| Smart Lock 3.0 | All white | |||
| Smart Lock 2.0 | Silver with black body (limited white edition) | Built-in door sensor | ||
| Smart Lock (1st Generation) | Silver with black body |
