Setting up the Smart Home Mode for Tap to Unlock
This article concerns:
The Keypad 2 NFC now allows you to use the “Tap to Unlock” feature. There are two Tap to Unlock modes: the Smart Home Mode and the Nuki App Mode. This article concerns setting up the Smart Home Mode.
Choose compatible devices
To use Tap to Unlock in Smart Home Mode, you will need a Keypad 2 NFC, one of the compatible Smart Locks or a Smart Module, as well as a Smart Home Ecosystem that supports digital home keys.
Compatible Nuki device running the latest firmware version
Apple
When paired with a compatible Nuki device, Tap to Unlock with Apple home keys is available for:
Apple mobile device with Apple Wallet and Apple Home App
  • iPhone XS and later running iOS 18.6 or later
  • Apple Watch Series 4 and later running watchOS 11.6 or later
Apple Matter/Thread hub
  • Apple TV 4K (3rd gen, 128 GB)
  • Apple TV 4K (2nd gen) with Thread support
  • HomePod (2nd generation)
  • HomePod mini
Samsung
When paired with a compatible Nuki device, Tap to Unlock with Samsung digital keys is available for:
Samsung mobile device with Samsung Wallet and SmartThings App
Samsung Matter/Thread hub
Activate the Smart Home Mode for Tap to Unlock
Set up Tap to Unlock and the Smart Home Mode with your Nuki App and Smart Home app. Manage it via your Smart Home app. You can activate Tap to Unlock during the initial Keypad setup or later via the settings.
Steps to activate Tap to Unlock:
  • First, open the Nuki App and tap on the Nuki device connected to the Keypad.
  • Go to “Settings” > “Keypad” > “Tap to Unlock”.
  • Then, select the Smart Home Mode.
  • The app will display information about the Smart Home Mode. Depending on your setup, you will either be guided through the Matter activation or directly to the Tap to Unlock activation.
  • For both, the Nuki App will display supported Smart Home apps (Apple Home or Samsung SmartThings).
    Simply follow the instructions in your Smart Home app to activate Tap to Unlock and to add a card to your wallet.
Note:
  • Make sure your Hub and Smartphone are using the same Wi-Fi during setup.
Tip!
Here, you can find mounting instructions for your Keypad 2 NFC. If you already have a Keypad 2, you can reuse its mounting plate.
Manage the Smart Home Mode for Tap to Unlock
All Tap to Unlock management must be done directly in the Smart Home app. This also includes adding or deleting Tap to Unlock users.
Would  you like to redeem an invitation for the Smart Home Mode? Simply tap the notification on your phone or open your Smart Home app to redeem it. Learn more about setting up and redeeming an invitation for Apple Home or Samsung SmartThings.
