Keypad setup instructions
This article concerns:
  • Keypad
  • Keypad 2
  • Keypad 2 Pro
After mounting your Keypad, set up your Keypad via the Nuki App. The app will guide you through the setup steps:
  1. Open the Nuki App on your smartphone:
    Open the menu (top left) and select ”Keypad” under ”Manage my devices”.
  2. Select the device you want to connect to your Keypad:
    The Nuki App shows you all devices that can be connected to the Keypad. Choose the Nuki access solution you want to control via the Keypad.
    If the device is already connected to another Keypad, the Nuki App offers you the option to add a new Keypad.
  3. Bring your Keypad into maintenance mode:
    Press the back key (◀) for five seconds until the LEDs on the Keypad are flashing.
  4. Set your Secure Code:
    Set your personal, 6-digit Secure Code. This code protects your Keypad from unauthorized access.
    Keypad and Nuki device are being paired now.
  5. Choose an entry code:
    If you want, you can already create your first entry code.
    If you have a Keypad 2 or Keypad 2 Pro you can also add a fingerprint after creating the entry code.
  6. Set lock settings for your Keypad:
    If you want, you can not only unlock the door but also lock your door using the Keypad.
Your Keypad is now set up and ready to use. After setting up your Keypad, you can manage the settings and entry codes in the ”Locking permissions” section via the Nuki App.
