With the Nuki App, you can easily reset your Nuki device.
How to reset the device
Select your desired device. Tap on "Settings" > "Features & Configuration" > "General" and then "Reset".
When you reset your device to factory settings, all data is permanently deleted. Neither settings nor user information is preserved. You can do this without your security code. After the reset, you can set up your device anew.
If you don't have access to your device through the Nuki App, reset it to factory settings via the Help menu. To do this, open the Nuki App menu and tap on "Help" > "Factory reset". Choose the product you want to reset and follow the instructions within the Nuki App. Now, all data will be permanently deleted.
