LED Signalization of your Smart Door
The Smart Door signals various states through its white LED:
State LED signalization of the Smart Door
Smart Door locked, inactive The LED ring is off. Led is off
Smart Door unlocked The top segment of the LED ring flashes 1x every 1.5 seconds. Led is flashing
Pairing mode
You can now connect the Smart Door with other Bluetooth devices.
The LED ring is permanently glowing. Led lights up
Maintenance mode
You can now i.e. reset the Smart Door to factory settings or update the firmware.
The top segment of the LED ring is permanently glowing. Led top segment lights up
Motor blocked After a locking operation the LED ring flashes evenly for 10 seconds. After that, the top segment of the LED ring flashes 3x every 15 seconds. Led is flashing
Incorrect Pairing between button and lock system LED ring flashes > 10 x after button press Led is flashing
Switch off the LED
You can always turn off your device's flashing and glowing. Simply tap on your device in your Nuki App, enter the settings, and go to “Features & Configuration”, “Button, LED  & Sound”, or “Button & LED”. Here, you can disable the LED signal. Switching off the LED signalization saves energy and prolongs battery life.
