If the Bridge is connected to your network and permanently online, firmware updates will be installed automatically. Updating the firmware can take between one and 24 hours.
This is how you check which firmware version is installed:
- Open the main menu on the top left in the Nuki App (three yellow bars).
- Select "Manage devices" > "Accessories" > "Bridge" and tap on „Manage Bridge”.
- Plug the Bridge into an outlet while pressing the button on the Bridge to activate the maintenance mode. Keep the button pressed for ten seconds until the LED starts flashing every second.
- Once the Nuki app has found the Bridge in maintenance mode, you can click on the Bridge-symbol. You will now receive the relevant information.
