Setting up the Smart Home Mode for Tap to Unlock
The Keypad 2 NFC now allows you to use the “Tap to Unlock” feature. There are two Tap to Unlock modes: the Smart Home Mode and the Nuki App Mode. This article concerns setting up the Smart Home Mode.
Choose compatible devices
To use “Tap to Unlock” in Smart Home Mode, you will need a Nuki Smart Lock, as well as a Smart Home Ecosystem that supports digital home keys.
Apple
When paired with a compatible Nuki Smart Lock, Tap to Unlock with Apple home key is available for:
Apple mobile device with Apple Wallet and Apple Home App
  • Apple Watch Series 4 and later running the latest software
  • iPhone XS and later running the latest software
Apple Matter/Thread hub
  • Apple TV 4K (3rd gen, 128 GB)
  • Apple TV 4K (2nd gen) with Thread support
  • HomePod (2nd generation)
  • HomePod mini
Samsung
When paired with a compatible Nuki Smart Lock, Tap to Unlock with Samsung digital keys is available for:
Samsung mobile device with Samsung Wallet and SmartThings App
Samsung Matter/Thread hub
Activate the Smart Home Mode for Tap to Unlock
Set up Tap to Unlock and the Smart Home Mode with your Nuki and Smart Home app. Manage it via your Smart Home app. You can activate Tap to Unlock with your Keypad 2 NFC during the initial setup or later via the settings.
Steps to activate Tap to Unlock
  • Open your Nuki App and select your Smart Lock.
  • Go to “Settings” > “Keypad” > “Tap to Unlock”.
  • Then, select the Smart Home Mode.
  • The app will display information about the Smart Home Mode. Depending on your setup, you will either be guided through the Matter activation or directly to the Tap to Unlock activation.
  • For both, the Nuki App will display supported Smart Home apps (Apple Home or Samsung SmartThings).
    Simply follow the instructions in your Smart Home app to activate Tap to Unlock and to add a card to your wallet.
Note:
  • You can only use Tap to Unlock in one Smart Home ecosystem. Apple Home Keys and Samsung Digital Home Keys cannot be used simultaneously for one Smart Lock.
  • Make sure your Hub and Smartphone are using the same Wi-Fi during setup.
Tip!
Here, you can find mounting instructions for your Keypad 2 NFC. If you already have a Keypad 2, you can reuse its mounting plate.
Manage the Smart Home Mode for Tap to Unlock
All Tap to Unlock management must be done directly in the Smart Home app. This also includes adding or deleting Tap to Unlock users.
Would  you like to redeem an invitation for the Smart Home Mode? Simply tap the notification on your phone or open your Smart Home app to redeem it. Learn more about setting up and redeeming an invitation for Apple Home or Samsung SmartThings.
