Your security is our highest priority. Of course, this also applies to the Keypad. The Bluetooth communication between the Keypad and the Nuki device is based on digital keys consisting of randomly generated, anonymous ID numbers and is encrypted end-to-end.Â
In addition, various security features are available to maximize safety when using the Keypad:
Security code
During the initial setup of the Keypad you have to define a 6-digit security code.
Entering the secure code is required whenever you want to manage your Keypad or connect another Smart Lock to the Keypad. The secure code therefore protects your Keypad from unauthorized access and theft.
You cannot manage or reset your Keypad without entering the secure code. Since the code is only stored on your Keypad, make a note of it so that you can manage your Keypad at any time.
Wrong Keypad entry code
When you use the Keypad, the code you enter is checked against the stored code. We keep you informed if someone entered a wrong Keypad entry code.
Activity Log
In the activity log every action performed on the Nuki device is recorded.
Besides the exact time of an action, the activity log also contains information about the user who unlocked the door.
When using the Keypad, the entered entry code is always compared to the stored code on the Nuki device. If the entered and the stored codes do not match the incorrect entry is noted in the activity log of the Nuki App. This way you can always track if and when a wrong code was entered.
Warnings
Nuki can send you notifications when a wrong entry code is entered. To activate these warnings, follow these steps:
- Open your Nuki App and tap on the Smart Lock that is connected to your Keypad.
- Enter the settings and select “Features & Configuration”.
- Scroll down to the Integration section and tap on “Manage notifications“.
- Log in with your Nuki Web account and activate the warnings.
If you haven’t a Nuki Web account yet, activate Nuki Web in just a few steps.
Protection against systematic code spying
To provide additional protection against systematic code spying, there will be a timeout for re-entering a code after a defined number of incorrect entries.
The following timeout duration is defined for incorrect Keypad code entries:
- Five or more incorrect code entries: Timeout of 30 seconds
- 15 or more incorrect code entries: Timeout of 3 minutes
- 50 or more incorrect code entries: Timeout of 30 minutes
