The status of your door is not only shown in the Nuki App but also directly on the Smart Lock by a LED signalization on the rotating ring.
In addition to the illuminated ring, the the Smart Lock has a red LED in the upper segment of the ring. This LED is mostly used to display errors and warnings directly on the Smart Lock. If the red LED lights up, open the Nuki App to get further information about the error or warning and troubleshooting steps.
Details on the Smart Lock's LED signalization
State |
LED signalization |
Smart Lock locked, inactive |
The LED ring is off. |
Smart Lock unlocked |
The top segment of the LED ring flashes 1x every 1.5 seconds. |
Pairing mode The Smart Lock can be connected with other Bluetooth devices. |
The LED ring is permanently glowing. |
Maintenance mode The firmware of the Smart Lock can be updated or reset to factory settings.
The top segment of the LED ring is permanently glowing. |
Smart Lock is charging The Smart Lock is now charging on or off the door.
The red segment of the LED ring first flashes and then glows dimmed. As soon as it is fully charged, the red segment turns off again. |
Door Sensor Door open
Door Sensor Door closed
The lower segment of the LED ring is permanently glowing. |
Error |
LED signalization |
- Battery state crititcal Please load the batteries. - Battery state of the Nuki accessory (Keypad or Door Sensor) critical Please replace the batteries. - No Wi-Fi connection - Nuki Door Sensor removed |
The red segment of the LED ring flashes 1x every 15 seconds (in total 4x). Note: The error signalization is displayed directly after the locking action. |
Uncalibrated The Smart Lock is not calibrated. The status was lost due to external influences. Please calibrate it with the Nuki App. |
The red segment of the LED ring flashes 4x every 15 seconds. |
Â
Switch off the LED
You can always turn off your device's flashing and glowing. Simply tap on your device in your Nuki App, enter the settings, and go to “Features & Configuration”, “Button, LED  & Sound”, or “Button & LED”. Here, you can disable the LED signal. Switching off the LED signalization saves energy and prolongs battery life.
