Smart Lock (U.S. Deadbolt): mounting & installation
The mounting of the Nuki Smart Lock U.S. on the inside of your door is easy. You can find additional installation information in this article.
Tip: Nuki App required
You will need the Nuki App to mount the Smart Lock. Simply open the Nuki App, tap on the menu (three bars at the top left corner), and select "Manage devices". If you are new to Nuki, open the App and select "Set up device". The Nuki App will guide you through mounting. The following instructions will give you some additional information concerning the mounting.
Overview of mounting the Smart Lock US: The mounting plate is fixed to the door with screws. Next, an adapter is placed on the mounting plate. The Smart Lock then goes on top of that.
PDF instructions:
As an alternative, we provided PDF instructions for installing the Smart Lock.
Check the base ring:
Before you start the mounting process, please check your base ring. Your Smart Lock comes with a black or white base ring already installed. Push it all the way against the stainless steel body. Make sure the ring does not cover the black mounting button on the back side of the Smart Lock. It must move freely.
To change the base ring, press the small black mounting button that holds the base ring in place. You can then remove the ring and slide the other one onto the Smart Lock.
1. Secure the lock on the outside of your door
Attach the door lock to the outside of your door using the supplied adhesive strip. This ensures that it cannot come loose while mounting the Smart Lock.
2. Remove the knob on the inside of your door
Remove the screws on the inside of your lock. Take off the knob and cover. You will need the screws later to attach the mounting plate.
After you have removed the knob, you can see the tailpiece.
3. Measure the tailpiece overhang
Use the measurement card to measure the tailpiece overhang on the inside of your door.
Place the card on the door and check if the tailpiece is within the markings.
Yes
Is the tailpiece's length within the green area? You can directly attach the mounting plate (Step 4).
Beware
Is the tailpiece's length within the yellow area? Mount the supplied extension plate (Step 3a).
Does the length of the tailpiece exceed the maximum length? Please contact our customer support.
3a. Extend the mounting plate using the extension plate
Is the length of the tailpiece within the yellow range of the measurement card? Mount the supplied extension plate.
  1. First, take the included extension plate and the screws.
  2. Remove the screws from the mounting plate to disassemble the mounting plate into its components (1, 2 & 3). You will need the screws later.
  3. Take parts (1) and (2) of the mounting plate. Place the extension plate on top of them. Then, place part (3) of the mounting plate on the extension plate.
  4. Screw the four parts together using the screws you removed to disassemble the mounting plate. Ensure that the markings on the mounting and extension plates are facing upwards.
4. Attach the mounting plate
The marking on the mounting plate shows you how to attach it. Make sure that the marking on the mounting plate is at the top.
Fix the mounting plate to the door using the screws you removed from your door earlier.
5. Choose the fitting adapter
Three adapters are included in the delivery. Choose an adapter that fits your door's tailpiece. Place the adapter on the tailpiece to connect it to the Smart Lock in the next step.
6. Mount your Smart Lock
Make sure that the marking on the Smart Lock is at the top. Then, turn the Smart Lock to the right until it snaps into place. You hear a clicking sound when it snaps into place. Your Smart Lock is correctly positioned if the lettering "Nuki" is centered at the top.
