This article concerns:
- Door Sensor
- Smart Lock 3.0 and newer
- Smart Module
The Nuki App will inform you as soon as a new firmware is available. To update the Door Sensor firmware follow these steps:
- Tap on the Nuki device connected to the Door Sensor in the Nuki App and open the device settings.
- Select ”Features & Configuration” and then ”Nuki Door Sensor”.
- Tap on ”Firmware update” to check for a new version.
- To perform the firmware update, simply follow the instructions in the Nuki App.
Note:
To update the firmware, you need to be within Bluetooth range to your Door Sensor.
