Reset the Door Sensor
This article concerns:
  • Door Sensor
  • Smart Lock 3.0 and newer
With the Nuki App you can reset your Door Sensor to factory settings. To do so, follow these steps:
  1. Open the menu (top left) of the Nuki App and tap on ”Help”.
  2. Tap on ”Factory reset”.
  3. Select ”Nuki Door Sensor factory reset”.
  4. Now follow the instructions in the Nuki App.
Note:
By resetting to factory settings, all data will be irrevocably deleted. After the reset, you can set up your Door Sensor again.
