To set up your Smart Lock with the Nuki App, install the app on your smartphone and open it. Then, the Nuki App guides you through the required steps.
1) Connect your Smart Lock with the Nuki App
You have to activate Bluetooth on your smartphone, so that the Nuki App can find the Smart Lock. When your Nuki App scans for the Smart Lock, hold down the button on the Smart Lock for 5 seconds until the LED ring is permanently glowing. Stay within Bluetooth range during the setup.
2) Calibration
During the initial setup, the Smart Lock calibrates itself and adapts to your door.
To re-calibrate your Smart Lock later, tap on the desired Smart Lock in the Nuki App and enter the lock settings. Then go to "Features & Configuration" > “General”.
Did you receive an invitation code for using a Nuki device?
To get access to the device:
- Install the Nuki App on your smartphone and open it.
- Select "Enter invitation code" and follow the instructions in the Nuki App
Is your device already set up?
You can pair the device with the Nuki App on-site via Bluetooth:
- Select "Add new Smart Lock". Follow the instructions in the Nuki App
To prevent pairing a smartphone directly with your Smart Lock, Bluetooth pairing can be disabled. Open the Nuki App and go to: "Settings" > "Features & Configuration" > "Button & LED" and deactivate the option "Bluetooth Pairing". If Bluetooth pairing is disabled, you can only add new users via invitation code.
