The Keypad contains six white LEDs that give you feedback on the status of the Keypad.
| State | LED signalization |
| Keypad inactive | LEDs off |
| Maintenance mode | LEDs flash back and forth in a repeating loop. |
| Tap to Unlock | LEDs flash from the inside out in a repeating loop (wave). |
| Error | LEDs flash briefly |
| Error while scanning or recognizing the fingerprint | 1x |
| Smart Lock is out of range / connection error | 2x |
| Authorization error | 3x |
| Keypad is deactivated in the user management | 4x |
| Locking currently not allowed, Keypad is limited in time | 5x |
| Keypad is not paired with any Smart Lock | 6x |
| Other error | 7x |
LED signalization when creating a fingerprint
You can open your door by typing in a 6-digit entry code or by putting your finger on it. A maximum of 20 fingerprints can be created per Keypad. The Nuki App guides you through the enrollment process. When scanning your fingerprint, you repeatedly lift and rest your finger on the fingerprint sensor. You get visual feedback about the progress in the scanning process directly on the Keypad.
Note:
You need the Keypad 2 to open your door with your finger. The first version of the Keypad does not have a fingerprint sensor.
| Progress in the scanning process | LED Signalization |
| Step 1: Initial check of the fingerprint. | The first LED from the left lights up. |
| Step 2 - 6: Every time the finger is placed on the sensor again, the fingerprint template that is created is refined. | After each successful step, another LED lights up until all six LEDs are lit. |
| Step 7: Final check of the fingerprint. | All six LEDs are filled from left to right. |
