How to replace the batteries of the Keypad 2
This article concerns:
  • Keypad 2
  • Keypad 2 NFC
Your Keypad works with four AAA batteries, which are included in delivery. On average the included batteries last at least 12 months.
The Nuki App keeps you informed about the battery level of your Keypad. If the battery level drops below 20%, the Nuki App will remind you automatically to change the Keypad's battery.
To check the battery level manually, follow these steps:
  1. Tap on the Smart Lock connected to the Keypad and open the settings.
  2. Select “Keypad“.
  3. In the Keypad settings you'll find all information about the battery.
Steps to replace batteries
  1. Detach Keypad from mounting plate: Hold the Keypad by the side edges of the housing and slide it upwards. Then pull the Keypad towards you to remove it.
  2. Open battery compartment: Locate the release latch at the bottom of the Keypad's back. Place your finger on it and pull the cover towards you, then slide the cover downwards.
  3. Replace batteries: Remove the old batteries and insert new ones. Ensure the correct polarity as marked on the Keypad.
