The Smart Lock performs a position run when it needs to check its current position.
For example, the Smart Lock Go, 4th and previous generations perform a position run after you change the batteries.
During a position detection, the Smart Lock turns the bolt as far as possible into the “locked position” and then back to the original position.
This position detection does not affect the functionality of the Smart Lock. After completion, the device will be available again without any restrictions.
Please note:
There will be no unwanted opening of your door, so there is no security risk whatsoever!
