Ring to Open with your Opener
With the feature “Ring to Open” you simply ring the bell to open the door of your apartment building.
About Ring to Open
  • Door opens after someone rings the bell.
  • Time frame from 5 to 60 minutes.*
  • Possibility to deactivate after ringing once.*
Activate Ring to Open
  • Press the button on the Opener.
  • Tap on your Opener in the Nuki App. Swipe up to see the “Ring to Open” button.
* Do you want to define how long Ring to Open should remain activated? Tap on your Opener in the Nuki App. Enter the settings. Then choose “Features & Configuration” > “Ring to Open”. You can choose a time frame from 5 to 60 minutes. Here you can also set it to deactivate Ring to Open after ringing once. For longer periods, use the Continuous mode.
Did you know that you can activate Ring to Open automatically? Simply enable Auto Unlock for your Opener. This feature basically activates Ring to Open as soon as you come near your home.
Does your intercom operate more than one door? No worries, Ring to Open, Auto Unlock for the Opener and the Continuous mode will always open the door that has been rung.
